Looking for Engine Compartment Bracket P/N
In preparation for putting the stock AFM back into my '87, I'm looking at what other parts I'm going to need, and I can't find the P/N in the PET for a specific bracket. It's the one outlined in red here:
![]() Looking at the PET, the other bracket that fastens to the same rubber buffer is #3: ![]() Any ideas?
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Undocumented User
It's an L bracket, i couldn't find it in the PET catalog. Do you need a Porsche L bracket? You can probably find something off the shelf in an auto parts or hardware store.
I might have one.
Lorne M.
83 SC |
My '87 does not have that bracket, --- not factory?
My 88 has the bracket and the blue attaching piece as in the photo.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
My 87 has it and clip
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
My 84 has this:
![]() It's a different style bracket but maybe it's not stock?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Just curious, what's in it now? if the AFM is out.
Wire insulated bracket.......
The insulated bracket for the wire harness is an added bracket and not original equipment or factory installed. You won't find any part number for this part because it does not exist.
Tony |
That bracket looks exactly like the wire holding bracket used on a 915 transmission to hold the speedo and reverse wires.
Lorne M.
83 SC |
My '84 Targa has the bracket as does my friends '85....both stock from the factory.
Jay Traner 1984 911 targa 1923 STuTZ 690 Touring 2014 VW CC 2.0T 2021 Subaru Forester (Mrs) |
Hey scarcellar, there is currently an aftermarket AFM in the car with a cone air filter. It has its own bracket instead that works for that shape AFM. It also has its own harness that connects from the factory harness into the AFM. I'll post a pic when I get back home this weekend.
Okay, I got the correct bracket for the AFM, and I ordered a transmission bracket that will work once I cut it down.
Now I need help with the PN for the omega clip. It's larger than the one for the cruise control cable. Anyone have any idea what this PN would be?
Blue 16mm
PN 113-142-261-A Cooper |
That's it! Thanks, Cooper! You wouldn't happen to know the correct PN for the bracket it goes in to, would you?
How did you find this one? It's not in the PET.
Hi WRX, sorry, don't know PN for the angle bracket.
The omega clip part numbers are hard to locate in PET. They are often found in the electrical diagrams. Problem is, they aren't called out in the exploded view, just text in the list. Typically called "cable holder" or clip. I obtained a list from the local dealer several years ago with each size, color, and PN spelled out. Very handy... Good luck with the rest of your air box "restoration". Nice to make things stock looking. Cooper |
Sounds like your dealer is a bit more "willing" than my local dealer. I inquired about both the bracket and cable holder, mentioning that I couldn't find it in PET. The response I got was, "yeah, they did some different things like that back then." Ummm, thanks?
The transmission bracket I ordered should work. I'll have to rebend it, trim it, and drill a new hole. No biggie.
Incidentally, armed with that PN and Google I came full circle to another post where Cooper provided the other PNs of the other sizes, and another Pelican took a pic of what he had:
Gray 10mm 477-971-851 Blue 16mm 113-142-261-A White 18mm 171-971-847-A Yellow 321-971-847-B Red 811-971-848-B Green 999-651-168-40 Black 181-971-847
Okay, I'm still looking for this part number. Yes, I suppose I could bend up another bracket and make it work, but I guess I'd rather have the correct one. Anyone?
