How to remove electrical connectors
I know this sounds like a dumb question but what is the proper way to remove connectors from the CHT connection or the idle control valve? I just want to be very careful that I do not break the connector. I do not see clearly how to disconnect them. Thanks, Nick
Old 03-12-2018, 11:47 AM
proporsche's Avatar
hi Nick just shake and pull on it that is all...you can use flat head screwdriver to help
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-12-2018, 12:05 PM
Brew Master
cabmandone's Avatar
There is a thin metal clip that closes onto the connector. You can use a screwdriver to pull the clip up and then pull the connector off.
Old 03-12-2018, 12:15 PM
proporsche's Avatar
usually you do not have to remove the clip it will pup of easily
here is the connector picture from inside
Old 03-12-2018, 01:12 PM
I just use a screw driver between the top of the plug (female) and the terminal (male) that it's plugging into to and just very gently twist the screw driver to lever it off. You have to be careful because the heat cycles over 30 years have made them quite brittle.
Old 03-12-2018, 02:03 PM
