Overseas72
Advice needed / storage to start up
Hi all, my 1974 911with CIS has been in storage for about 7 months . The battery was on a tender and I know it will start . I just don't want to damage anything by just starting it up after sitting up. Any advice on the matter ? Thank you
shh-the robot is sleeping
7 months is a long time for me. But. Don’t over think it. It’s an engine.
Make sure there is fresh gas, unless you used a stabilizer with a full tank prior to storage. Then, make sure you have good oil pressure and some oil moved around before it fires up. I would tend to give it a few cranks with the the ignition coil disabled. This would circulatate the oil to some likely unoiled areas. Perhaps overkill: remove the plugs, spray some penetrating oil into the cylinders. Do a few hand cranks to get the juices moving. Check the fuel / electrical lines for chew marks (mice love those engines near me) / degradation, belts, hoses etc... Make sure the brakes / fluid are operational before you set out! Check you lug nuts, tire pressure and condition, lights, common safety items. Make sure no rat / mice nests are in the common areas and can catch on fire.
'88 911 Coupe, 69k miles Last edited by da Vinci Dan; 03-11-2018 at 02:50 PM.. |
Maybe crank it with the ignition disabled, per the above suggestion, but I don't think you really need to do any more than that and check for critters if they are a problem in your garage. Just fire it up and go. Seven months isn't a long time for me; I had a car sitting for eight years and it didn't need more than fresh gas in it.
'80 SC Targa Avondale, Chicago, IL |
Make sure you inspect those fuel lines regardless of the amount of time in storage. My '75 built in '74 had some serious potentially fatal flaws what I have discovered after pulling it all out.
Hop in the car and start it. It will be fine. I store all my cars for 7 months over the winter and they all start on about a half of a crank. If your going to store it for long periods I fill the tank add 55 lbs of pressure to the tires and pull the battery put it on a tender.
Troll Hunter
For Pete's sake, it was 7 months not 7 years.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Counterclockwise?
7 months. Here we call that winter!
Just fire it up.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
