47silver's Avatar
1972 911 with mfi spark plug wire routing
i was dumb and forgot to take pictures of how the braided plugs wires are installed on a 72 mfi ingine
do they go through the mfi stacks at the location of the fuel lines?
do they go round the stacks?
any pictures or help is appreciated
i did search here and on google
1975 911S Targa
Silver Anniversary Edition
Old 03-18-2018, 02:44 PM
skinnerd's Avatar
Yes the passenger side plug wires go thru the throttle bodies and use the same rubber brackets that the fuel lines use.
I have personally not seen the braided spark plug wires used on MFI motors....those are usually seen on the CIS motors I think.
I could be wrong.
I've had two of the MFI motors and they always had the Beru style spark plug wires.
If you google MFI motors, you will see some with the braided lines?
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 03-18-2018, 03:15 PM
47silver's Avatar
thanks
Did not know they were beru.
The wires i removed were braided with the ground lugs at the coil bracket. And car was in storage from 1984 til i bought it.
Do berus have shields too?
Old 03-18-2018, 07:19 PM
skinnerd's Avatar
The only shielded wiring is the coil to CDI box wiring on my car.
You would see the ground lug at the coil bracket and a ground connector on the CDI box as well.
My understanding is that Beru is the go to spark plug wire for MFI motors although some people use the Clewett wiring as well.
Doug
Old 03-18-2018, 09:10 PM
47silver's Avatar
beru it is then
1975 911S Targa
Old 03-26-2018, 12:09 PM
