911 Gauge refurb question
First
Are these 68 dials ??
They look flat and is it viable to pop the glass and clean them up ?? I'm not looking at dropping them at a gauge resto joint and spending a fortune.
Any tips or advice. ?????
Thanks Lyndon
Old 03-28-2018, 12:30 AM
Cars and Cappuccino
tdw28210's Avatar
Remove one or two and post close up pics of the front and back and the hive will chime in.
Old 03-29-2018, 01:42 PM
Under the radar
Trackrash's Avatar
There will be, or was, a date stamped on the rear of each gauge.
I'm not sure when Porsche went to the silver bullet in the center, but I thought it was '69.
Up to '70 there are two mounting screws in the rear that hold the gauges in place. Starting in '70 that was eliminated and only the rubber ring around the gauge held them in place.
If you take some of your gauges out and show some high quality pictures of the rear, we should be able to tell what they are.
Or maybe you can see from the inside of the frunk.....
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-29-2018, 02:40 PM
Yes, they are '68 gauges.
1969 911E 2.0 restoration project in progress...
Old 03-29-2018, 02:46 PM
I will get one out. Is something an amateur can do ??? Remove the glass or let sleeping dogs lie
Lyndon
Old 03-29-2018, 03:48 PM
Uncertifiable!!!
Uwon's Avatar
Not easy to open up without damage. Send them to Hartmut at Palo Alto and save yourself allot of grief and disappointment. Ask me how I know.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-29-2018, 07:39 PM
porschetub's Avatar
Oh come its not that hard,if they work a cosmetic DIY is easy enough to if you take your time,the glass bezel takes work to get off but easy to clean up the glass,gauge face and recolour needles,its amazing how much dust and cr#p gets inside them.
Done around 5 of them now and they all cleaned up nicely,for an improvement in lighting I started with LED replacement lamps....good result but wanted more so when to LED strips are a great upgrade.
If you are DIY (again) you can test most functions of your gauges with out a running engine,let Google be your helper in this case.
If not a DIY guy send them out for repair as the set you have are rather valuable,good luck ,cheers
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 03-30-2018, 12:44 AM
Just be wary, good friend tried to help me fix my speedo's odd gear (usually most of the dust in a speedo is the odd gear bits). He has done many of them without an issue, and the needles shaft broke on mine trying to get it off. He had a needle puller too. Thats a $400 bill to get fixed.
Been talking to a few speedo shops about re doing an entire set for me. Stock refurb seems to be $1,200-$1,500 and if you want a color change (say green lettering instead of white) that adds about $700 to the job. That said they come back factory fresh.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-30-2018, 01:17 PM
Looks like November 67
Old 04-01-2018, 06:11 PM
Cars and Cappuccino
tdw28210's Avatar
Yep, right there in the lower corner. Seems about right for an early production date '68.
If you just want a refurb and not heavy customization you can try Nichols Speedometer in Greensboro, NC - a longtime VDO shop. This place, along with Hartmut at N. Hollywood Speedo were apparently the only official VDO repair places back in the day. Charlie Nichols has been there since the 70's. He told me a story about how he went into the old VDO factory in Winchester, VA and picked up boxes and boxes of parts when they were closing it down. My repair and resto with them was pretty quick and reasonably priced. Good luck.
Nichols Speedometer & Instruments - Speedometers, Tachographs, Service and Repair North Carolina
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 04-02-2018, 03:45 AM
+1 for Nichols Speedo. They did all the instruments from my 70 after a fire. Did a great job and
it didn't take a lot of time. Don't have to send them to Cali and wait for months.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 04-02-2018, 03:54 AM
I'm in Australia. I have removed them and just given them a good clean. The next owner can a full resto if they wish. I may remove the glass at a later stage and clean.
Lyndon
Old 04-02-2018, 04:09 AM
