-   -   Is there a way to check if an engine is sealed up properly before installing? (http://forums.pelicanparts.com/porsche-911-technical-forum/991981-there-way-check-if-engine-sealed-up-properly-before-installing.html)
JonT 03-28-2018 01:11 PM
I would assume running it on a dyno would be a logical move but is there something that can be done BEFORE or in lieu of dyno testing to ensure case halves/ other areas of leaking sealed properly?
Tyson Schmidt 03-28-2018 01:51 PM
No.
boyt911sc 03-28-2018 02:38 PM
Engine test stand.........
I run my engines on an engine test prior to installation in the car. After the test run, all you need is bolt the motor back and drive the car.
http://forums.pelicanparts.com/uploa...1522272653.jpg
Tony
mepstein 03-28-2018 02:47 PM
test stand
juanbenae 03-28-2018 02:53 PM
if a newly sealed motor is leaking you have bigger problems than another motor drop....
Trakrat 03-28-2018 02:58 PM
The best thing to do is verify the proper torque settings on everything. I will make a checklist of each nut I use to attach the 2 halves together and then check off each as I verify torque.
I have a tendency to get distracted and might end up missing one of the places that needs to be tightened.
T77911S 03-29-2018 04:34 AM
not practical for a one time rebuild.
tony does enough rebuilds a test stand is worth while. also a requirement if you build an engine and ship it and let the owner install it.
just put it in.
JonT 03-29-2018 11:12 AM
and that's my issue the build is in another state and being shipped back to me
Flojo 03-29-2018 11:16 AM
Why send it to the builder you obviously not trust in the first place??
Tippy 03-29-2018 12:30 PM
These motors have lots of areas that can lead to leaks from the initial install.
Case through bolts with oil around them, many seals, JB Weld covered studs, lots of aluminum or aluminum mating surfaces, etc.
These motors remind of old Chevy V8's, they leak like sieves unless you've been building them for a long time and know what to look out for.
