Bilstein roll pins
1984 911 3.2. Doing strut inserts... first question, never reuse roll pins correct? I'm missing a roll pin on the new inserts. 2nd question better to press the roll pin. Thx
disband
correct. if you are ready to reassemble and done want to be held up just reuse an old one for assembly while the new one(s) can be ordered. you can hammer them in, they generally go in relatively painlessly. hammer will also give you a better idea if it's hanging up any where a press would simply push a misaligned pin with sheer force.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Hilbilly Deluxe
Buy a set of roll pin punches, if you don't have them No better way to screw up a roll pin than to try and use a standard flat pin punch on one.
Also pay attention to the orientation when you put them in, the "split" faces away from the shock shaft.
Matt - 84 Carrera |
Fleabit peanut monkey
Have read this lots.
1981 911SC Targa |
Formerly known as Syzygy
A flat punch is a no-no on roll pins? Good to know. In the past, I've just used a brass hammer to set them flush and then a flat punch to tap in any further amount required.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 03-31-2018 at 07:38 PM.. |
Hilbilly Deluxe
I wouldn't say it is a no-no, but it is pretty easy to hork up the pins if you are not extremely careful. The roll pin punches have a little tit that centers them in the pin, makes it much easier to keep it aligned and not chew anything up.
