Headlight and wiper realy question
Is this the head light relay. Behind the left head light. Just sorted my seized wiper motor but it works regardless of ign switch position. I believe its fed via this relay. So I want to start there.
Lyndon
Kroon Wire Harnesses
Horn relay
This is the Wherle relay for the horns, used on 65-68 911 and 912's
Kroon Wire Harnesses Specialized in Classic Porsche electrics www.kroonwireharnesses.com Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses |
Great thanks. That clears that up. Where will I find the headlight relay ???
Lyndon |
Headlight relay
The headlight relay is grey (also Wehrle , part number W-598A/S) and located on the left, above the pedal cluster.
Great. Will sort it tomorrow. Need to switched power to the wiper motor.
Lyndon |
The window wiper should be working regardless of the ignition switch, its the red wire on the 4th fuse and always powered.
Well that's what its doing. My bad. I just assumed it would be acc and on only via ign switch.
Lyndon |
I do agree its seems not logical !
76 911S Targa
Headlight relay? Unless one was installed by the previous owner the headlights do not switch through a relay. Headlight relays are a good idea. I have them but I had to install them myself aftermarket.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Eng-o-neer
What year/car is this? The later cars don't have headlight relays...I would be surprised to see one on an earlier car.
Its a 68. My wiring diagram shows one. My wiper motor is powered thru it. Makes sense as the lights are not ign switch sensitive
Lyndon |
Headlight relay
Maybe " headlight relay" is not the right word for it, its actually the " lichthupenumshalt relais" or "relay for light signal" (No.43 on the original Porsche diagram)
Under the MPH on the Speedo. I have a green light. Is this telling me the lights are on ??
High beam is in the tacho ?? Lyndon |
![]() On the left in the driver's footwell Headlight relay |
