911SC Widebody Conversion Thread
In the spirit of my last build thread, which started way earlier than the actual project, I'm going to do the same here. I'm pulling the trigger on going as goofy-wide as possible with my fresh SC turbo conversion. Think RWB, but without the price tag.
I can't tell you guys how much you all helped with the turbo project, so much so that I wouldn't dare take on any large custom job without my Pelican Peers. I'm already looking for some info, so please sound off below if you have any insight.
- The Car (Relevant Info) -
- 1980 911SC, California car it's entire life. Zero rust... tight as a drum.
- Torsion bars that are slightly stiffer than a 930... I forgot the specs.
- New Bilstein shocks, bump steer kit, all new hardware.
- 17 X 8 ET 33 (Front 225s) 17 X 8.5 ET 24 (Rear 255s) Kinesis 3 piece wheels.
My main concern right now is getting the wheels/tires right. I don't want to change to coilovers so my height adjustment will be limited. It's currently at Euro-height. Since I have three-piece wheels, would I just have to get new outer lips at the proper extended length? The inner barrels should be correct, the distance inwards wouldn't change... right?
I've gotten very lucky with wheel sizing and offset in the past without fully understanding it. I'll probably need some help getting this right.
I'm a stone throw from the Better Bodies shop here in San Diego. I'll probably be heading down there with the car later this month. They offer a kit with 13'' flares, pretty much exactly what I'm looking for. I'm going after a bolt-on appearance, so there shouldn't be a massive amount of bodywork involved.
Thanks for checking out the new thread. I always appreciate my fellow members!
Old 04-03-2018, 11:19 AM
Administrator
Dmitry at Pelican Parts's Avatar
Really looking forward to following this build. As far as wheel sizing and offset, take a look at the link below. It's a great guide with some good points to follow - hope this helps you out a bit!
Wheel Fitment and Spacing Guide
Old 04-03-2018, 11:33 AM
Registered Minimalist
75 911s's Avatar
This guy got it done for about 10k. His wheel budget is probably more than yours. Wheels are key on this conversion imho. He did the bolt on look too.
Budget Wide Body Project
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-03-2018, 01:27 PM
I bet I can do it for under 5k. That's the plan.
- His cost included a 2k wing and 3.2k paint job. Oh and 6k wheels. Thanks for that thread though, it cleared up a lot of concerns. Kyle actually inspired my turbo project.
Old 04-03-2018, 02:50 PM
dos531's Avatar
FYI Better Bodies doesnt have the best reputation for quality. Hopefully since you're local you can get them to help you out. That and the youtube clout should help a bit. Have you thought about a 934 style widebody? Maybe not as wide as you want, but has a really timeless race car look. The 934 and the dzug project mjolnir are some of the best looking widebodies imho. If you like the fuchs look, I know rota has the 15x9, 15x11 setup for $1599 now. Add a couple reasonable spacers and it would look killer.
Ive been following your videos and it seems to be turning out great, so im sure itll work out whatever you decide.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 04-03-2018, 03:45 PM
David 23's Avatar
IMO 17" wheels are too large, and aren't going to have the right look. I'd suggest you go 15".
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 04-03-2018, 08:31 PM
Brando
quattrorunner's Avatar
tires are an important part of the decision making process. 17" makes sense in this case.
Turbo powa!
1977 911s. it's cool
Old 04-04-2018, 10:46 AM
H-viken's Avatar
You can always copy the 935 and go with 19" wheels in the rear Personally I'd stick with 15", looks best in my opinion
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 04-04-2018, 11:21 AM
Sboxin's Avatar
We also have 17" Kinesis wheels that came with the '78 911 SC race car. When we
recently did the Turbo 11" wide body conversion we took the rear 9" wheels and
moved them to the front with 245/40/17 Hoosier R7s - - - and asked Bogart Racing
Wheels to make new outer barrels for the rear wheels, keeping the inner barrels the
same. The rears are now 10.5" with the Kinesis centers and 315/35/17 Hoosier
R7s. Most recently we had a rear stub axle failure and the left rear wheel came off
the car at 80 MPH on track. Bogart then made another outer barrel for that
damaged wheel - and determined the Kinesis bolt pattern is NOT a standard 40 bolt
pattern - had to use the Kinesis center as a pattern. Also, we have had to use
spacers with the Kinesis wheels to clear the fenders, the oil lines and
trailing arm bolts - this is trial and error to get the 1/2" clearance we now have -
and alignment makes a difference too because of the close tolerances we are
running. The front is also very close to both the coil over springs and Turbo fenders.
You will have more room to work with by converting to the 13" fenders.
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 04-05-2018, 09:05 AM
