BlueWing's Avatar
Wehrle Relay Rating
Does anyone know the contact rating for the round black Wehrle Relays?
I have them installed as headlight relays. My low optioned SC had the available empty positions so I added a 3 position fuse block (factory) on the fuse /relay panel to fuse the wires going to the dimmer switch and 2 relays for the headlights.
I'm just wondering if the contacts are rated for the headlight load. I do not recall the wattage of the bulbs I have but I can adjust that to match the contacts if needed.
I have searched but just can not come up with the specs.
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 04-05-2018, 03:09 PM
(man/dude)
Jonny042's Avatar
I'm sure even if you have 100W bulbs you'd be fine. 200/12=16.7amps - that really isn't that much.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-05-2018, 06:46 PM
BlueWing's Avatar
Thanks Jonny042, thanks to Ohm's law for your calc. My questioning was I couldn't find the spec and not knowing what the other relay switched devices are on our 911s draw.
Would I be right thinking the high beams would be my highest current draw or would the fogs be higher (I don't have)?
Just for reference I only had a fuel pump and a horn relay up front and rear window defroster and heater blower in the rear.
Without knowing these loads had me concerned. I did clean up any connections at the time and have one relay for low beams and a second for the high beams. I like the factory look and when these relays were cheap and plentiful picked up a handful.
I have added fuses for the stalk feeds and the dash lights as well.
Terry
Old 04-06-2018, 07:13 AM
(man/dude)
Jonny042's Avatar
Terry
I'm sorry I couldn't be more help with actual ratings - I looked at a Wehrle Relay and a "made in china" one today and there was no clue on either one, but suffice to say the loads that the factory deemed worthy of relay control are higher that a couple of headlight bulbs. Wire them up and be happy. I think it's a great idea to use them, for the factory look, like you said.
Old 04-06-2018, 04:39 PM
(man/dude)
Jonny042's Avatar
I did a little more research and by the looks of it you would have a hard time purchasing a 12V relay with a current rating of less than 20 Amps. You're fine
Old 04-06-2018, 04:44 PM
BlueWing's Avatar
Thanks Jonny042, I've got a road trip coming up this summer and just going over anything I got in my mind.
I've felt the relays and wiring after using them and didn't feel any alarming temps. I got to throw an amp meter on them for a base line I guess.
Here is a picture when I was installing them. Got a few sockets at the Hershey Swap a few years ago and had plenty of positions to install them. The high beam relay is not yet in when the pic was taken.
Terry
Old 04-06-2018, 05:11 PM
