Wehrle Relay Rating
Does anyone know the contact rating for the round black Wehrle Relays?
I have them installed as headlight relays. My low optioned SC had the available empty positions so I added a 3 position fuse block (factory) on the fuse /relay panel to fuse the wires going to the dimmer switch and 2 relays for the headlights. I'm just wondering if the contacts are rated for the headlight load. I do not recall the wattage of the bulbs I have but I can adjust that to match the contacts if needed. I have searched but just can not come up with the specs. Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires |
(man/dude)
I'm sure even if you have 100W bulbs you'd be fine. 200/12=16.7amps - that really isn't that much.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Thanks Jonny042, thanks to Ohm's law for your calc. My questioning was I couldn't find the spec and not knowing what the other relay switched devices are on our 911s draw.
Would I be right thinking the high beams would be my highest current draw or would the fogs be higher (I don't have)? Just for reference I only had a fuel pump and a horn relay up front and rear window defroster and heater blower in the rear. Without knowing these loads had me concerned. I did clean up any connections at the time and have one relay for low beams and a second for the high beams. I like the factory look and when these relays were cheap and plentiful picked up a handful. I have added fuses for the stalk feeds and the dash lights as well. Terry
(man/dude)
(man/dude)
I did a little more research and by the looks of it you would have a hard time purchasing a 12V relay with a current rating of less than 20 Amps. You're fine
Thanks Jonny042, I've got a road trip coming up this summer and just going over anything I got in my mind.
I've felt the relays and wiring after using them and didn't feel any alarming temps. I got to throw an amp meter on them for a base line I guess. Here is a picture when I was installing them. Got a few sockets at the Hershey Swap a few years ago and had plenty of positions to install them. The high beam relay is not yet in when the pic was taken. Terry
