Head removal on 1980 911 SC US
Removing cam sprockets and have 19mm bolt in lieu of 46 mm nut. Have sprocket holding tool but no one to help me. Acc to Wayne's book, it is nearly impossible to remove the bolt while holding the sprocket in place without two people. I am inclined to agree. Anyone have any idea if I will create problems for myself by trying to remove the bolt with an impact wrench?
Thanks, Darwin
Old 05-23-2018, 05:53 AM
An impact wrench always has the potential to create problems. Have you tried a long breaker bar 2 1/2 ft ish? I would try long breaker first then go to impact gun.
Old 05-23-2018, 06:08 AM
Is it in the car or on a engine stand. I have done it by myself many times. Removal with impact wrench is fine, just don't install with it
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-23-2018, 07:03 AM
Impact wrench.
206 637 4071
Old 05-23-2018, 09:19 AM
proporsche's Avatar
same here i had no problem to remove the but holding the cam with toll in place.Also impact is ok even thou i do not like it much...because you can screw up your fork tool or the nut..
as said do not use impact on install
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-23-2018, 09:47 AM
Under the radar
Trackrash's Avatar
I used a pipe to extend the holding tool's handle, and a long breaker bar on the nut.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-23-2018, 10:16 AM
Engine is out and on a stand. NP putting it back together with torque wrench. I will have help by then to secure the sprocket. Was just concerned because it seemed the obvious way to remove it but wasn't mentioned in the book. Thanks for the help.
Darwin
Old 05-23-2018, 10:17 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Six point impact socket. No twelve point.
1981 911SC Targa
Old 05-23-2018, 12:31 PM
I don’t see how a second person could help. You place the two handles close to parallel and torque one against the other. It would be harder trying to stabilize yourself and another person pushing in opposite directions.
Old 05-24-2018, 07:17 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
A hundred times easier, and with less possibility of component damage, to use an air impact (as others have mentioned) - don't even need to hold the sprocket with anything.
Old 05-24-2018, 08:01 PM
