Part ID please
What is this? The piece in question has the wires leading into it and a coil or spring.
http://forums.pelicanparts.com/uploa...1523378967.jpg |
A/C Blower fan resistor. The housing is the air inlet for the A/C evaporator.
Thanks!
Car has heat and A/C deleted so it gotta go too |
Before I tossed this part I used it to make a template to block the hole with a thin piece of sheet metal.
What do you use to cut the sheet metal? Did you get the metal from Lowe’s or Homedepot or someplace more specialty?
I just used a piece of flashing from the harware store, tin snips, a file/sand paper and some paint. Reused the hardware that holds the resistor as well.
| All times are GMT -8. The time now is 08:44 AM. |
