strange electrical issues, turn signal switch???
my new to me 1980 SC
-cardboard shoved in turn signal switch to lock on High Beam, so that shows some issues I know, but question is would it have effect on any of these? 1) no driver front running or turn signal, does have driver maker light 2) neither front turn signals work, rears do 3) no driver side rear brake light, but passenger does work -took all items apart (did find some bad grounds) but can't find anything else wrong -all fuses are wring out good ideas from our fleet of geniuses on PP?? SmileWavy thanks, Steve |
experienced the same
theres some good articles on repairing turn stalk , i would suggest start there...if that doesnt work, you really have to check all grounds..in my case it was the driver parking lamp that was not grounded and created havoc with turn signals working as well as intermittent brake light
let us know what you find :-) |
Read this one from post 1...
http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html |
great tips, thanks guys, thread spoke on topic of fuses and contacts needing cleaning maybe
-car did sit for 22 years in humid Georgia, going to check that also, horn only clicks the relay but won't fire |
https://www.pelicanparts.com/techarticles/pcar_com/964_horn_repair.htm |
ok didn't get to the turn signal switch yet, did do some of the fuses and have more items working, found I need a new battery as one in there is too small and has no lower lip to grab the hold down clamp, going to tackle horn next, thanks again to all that helped
did find issue with Right head light, the low and high beam headlight fuse doen't have the wire going to ithttp://forums.pelicanparts.com/uploa...1523836763.jpg
does power come into the bottom or the top of the fuse block?
| All times are GMT -8. The time now is 10:59 PM. |
