smarens's Avatar
Question strange electrical issues, turn signal switch???
my new to me 1980 SC
-cardboard shoved in turn signal switch to lock on High Beam, so that shows some issues I know, but question is would it have effect on any of these?
1) no driver front running or turn signal, does have driver maker light
2) neither front turn signals work, rears do
3) no driver side rear brake light, but passenger does work
-took all items apart (did find some bad grounds) but can't find anything else wrong
-all fuses are wring out good
ideas from our fleet of geniuses on PP??
thanks,
1975 914 1.8l
1979 911SC Targa - In Restoration
1972 Pantera
Dune Buggy Dual Port 1835cc
1980 911SC Targa - Driver/Winter Project
Old 04-14-2018, 03:32 PM
7783911's Avatar
experienced the same
theres some good articles on repairing turn stalk , i would suggest start there...if that doesnt work, you really have to check all grounds..in my case it was the driver parking lamp that was not grounded and created havoc with turn signals working as well as intermittent brake light
let us know what you find :-)
Old 04-14-2018, 03:56 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Read this one from post 1...
turn signal switch quick fix pictures
Who Will Live... Will See
Old 04-14-2018, 04:41 PM
smarens's Avatar
great tips, thanks guys, thread spoke on topic of fuses and contacts needing cleaning maybe
-car did sit for 22 years in humid Georgia, going to check that also, horn only clicks the relay but won't fire
1975 914 1.8l
1972 Pantera
Old 04-14-2018, 06:00 PM
wrxnofx's Avatar
The horns are probably out of adjustment. Check this article out:
https://www.pelicanparts.com/techarticles/pcar_com/964_horn_repair.htm
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-14-2018, 09:53 PM
smarens's Avatar
ok didn't get to the turn signal switch yet, did do some of the fuses and have more items working, found I need a new battery as one in there is too small and has no lower lip to grab the hold down clamp, going to tackle horn next, thanks again to all that helped
1975 914 1.8l
1972 Pantera
Old 04-15-2018, 03:29 PM
smarens's Avatar
did find issue with Right head light, the low and high beam headlight fuse doen't have the wire going to it
1975 914 1.8l
1972 Pantera
Old 04-15-2018, 05:00 PM
smarens's Avatar
does power come into the bottom or the top of the fuse block?
1975 914 1.8l
1972 Pantera
Old 04-15-2018, 05:02 PM
