In the Triangle...
I'm trying to address the oil drips, and other than at the bottom of the bell housing, the only other currently wet and crud covered area is in the Devil's Triangle aka TOD. If your first notion is reply with something like "There's any number of threads dealing with this, do a search", please don't. Other than undertaking this in the first place, I'm not altogether stupid, and I've read through countless posts from guys who've done what I'm attempting. There's a few things missing from them, but it might be a situational thing, peculiar to my car or theirs.
It's my hope to do this without even a partial engine drop, and I'm really trying to avoid futzing with the fuel line/rail/injectors/harness connections that would accompany removal of the RH half of the intake manifold. With the airbox, AFM, rubber elbow removed, and some stuff shoved out of the way, I can get my hand in there and for sure R&R the oil pressure switch, maybe even remove the two thermostat bolts. But beyond that there something that would be in the way of lifting the T-stat up and out... the tan colored rather stiff and unmanageable cable that doesn't seem to have enough slack in it to shove IT out of the way. Anybody got an idea as to where the other ends of this thing is, and can I loosen it somewhere to get enough slack to get it out from on top of the T-stat. You'll see it in the photo below. For what it's worth, the grimy crud on and around the breather cover was dry, and the oily wet spots where the switch and T-stat. http://forums.pelicanparts.com/uploa...1523919389.jpghttp://forums.pelicanparts.com/uploa...1523919515.jpg |
The tan cable running across the back is fuel injectors plugs.
Removing air flow sensor and air cleaner gives you some access but most you need is clean to open the oil galleys I would pull the right half of the injection and change the breather hose too. You ll need 6 intake gaskets. Don’t lose the small thick washers that are on the intake at the heads The gray across the thermostat is the main harness from alternator to the starter. Bruce |
Thanks Bruce. I was hoping to avoid R&Ring the right half of the injection, but it would certainly provide more access to scrub the area. I'm with you as far as it not being good to open the oil galley with this much crud. If I pull the neg cable at the battery, and free the connections at the starter, would that cable running to the alternator then be able to be shoved back through the firewall (I assume there's a rubber grommet or something) enough to provide room in there?
As for removing the right side injection (manifold), from the look of things I'd have to disconnect the transverse fuel line from the damper, and the same thing at the other end of the fuel rail beneath the a/c compressor (which would also have to be set aside). Would snipping the tie wraps securing the injector harness to the rail and disconnecting the three connectors to the injectors enable the injectors themselves to remain with the manifold and the whole thing to be removed as an assembly? I want to minimize the amount of fuel connections I disturb. I suppose there's always residual gas in the lines and rails to be careful of spilling, but is there any check valve that maintains fuel pressure in there so it sprays everywhere when I crack open the first fuel line fitting? |
Good luck Jason |
Final report (I hate when I'm reading an interesting thread and the OP never posts the end result, or which of the 5 opinions of what might be wrong was correct... not that this was all that interesting).
Did not need to remove any intake hardware other than what I initially described. Undid battery and removed cabling at starter to slacken that alternator cable, and R&Ring T-stat went well (black o-ring snapped in half as so many others have mentioned), and I epoxy'd the new switch before installing it. I removed the clamp and pulled the breather hose to inspect (why in the hell are there little studs on the cap nozzle?). Hose was pliable at the end, so I did not replace. Bought the breather cap gasket and seal washer for the temp sensor, but after studying the area, all I had in the way of crud was older, baked on stuff and all the moist, fresher looking oil mess was centered near the two things I already replaced. As more complicated dismantling of stuff in the way would be needed, I flipped a coin and gambled on 2 out of 3 being enough. I reinstalled everything I took off and restarted the engine to inspect what I could see through the hose jungle and there was no evidence of fresh oil... red switch and shiny silver T-stat looked good to me. After a couple days of driving around, all is still well. There's still some drips underneath, but far fewer than before. Hoping it simply residual oil crud that's dripping down the side of the case after warmup, and will eventually dry off totally. A guy can dream, eh? I'll deal with the breather cap gasket if/when it starts looking wet up on top again. |
You did perfect.
To battle my leaks I removed the whole cis box and just finished installing. My car has been neglected so lots has to be done and was good to address the black broke immediately oil thermostat ring, new oil pressure switch and gaskets. What I did notice by someone pointing is that at the bottom of the cis box here is a hose (small) that goes outside the metal plate and on the side of the oil cooler. I didn’t have this and my guess is that this can cause oil leaks and exhaust smell if not addresses. Here are photos of this gizmo and my tod before and after. http://forums.pelicanparts.com/uploa...1524891357.jpg http://forums.pelicanparts.com/uploa...1524891414.jpg http://forums.pelicanparts.com/uploa...1524891509.jpg http://forums.pelicanparts.com/uploa...1524891548.jpg |
| All times are GMT -8. The time now is 08:46 AM. |
