Can I remove my dash w/o front window removal?
Hey Guys,
I am wondering if I can pull this off, I need to get my dash out but DO NOT want to pull the front wind screen! can this be done? Thanks! Eric 78SC
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
Team California
Someone will chime in w/ the definite answer, but as I remember the answer is no. Hope I'm wrong for your sake.
Denis |
I think it was no through 1985; then it went from unlikely/impossible to difficult. I seem to recall the problem is the line of fasteners at the very front of the dash which were too difficult to get to with the glass in place. Cheers, Jim
you can get it out, and damage it in the process, but the screws that hold the front lip down, real close to the rubber seal, can't be removed, or re-installed with the glass in.
Damn!!
I was hoping that you guys wouldn't say that!! ugh... I guess I'll have to pull off what I am trying to do with oUT! pulling it out..Thanks for the FAST! and insightful replies.. You guy's do indeed rock, you are always helpful and fast when a fellow Pelican needs a bit of help. Thanks again! Eric
Pre Registered
However, on '86 and later cars (with the long single center vent) there is no need (or any advantage) to removing the glass. Pulling the glass on those cars doesn't increase access to anything. Good luck, Tim |
