'76 Porsche 911S Targa - Engine Rattle
Hello, fellow 911 owners.
I recently inherited a '76 Porsche 911S Targa. It is a car my father spent endless hours on, he wrecked my aunts 911 and so moved her engine into a new body. It's a car that is used in the summer and even then it didn't get many miles. The list of known issues are as follows: Oil Leak - looks to be from the sump and valve covers. Battery Drain - currently being looked at but battery would be flat within 30 minutes ![]() Engine Rattle - Sounds like a push rod My main concern is the latter, I needed to put 4/5 quarts of oil in before the dipstick read anything, meaning it has sat for over two years with little oil. I have read that the rattle can be because of this and once its running and oil is being moved around the rattle should disappear. My question is this. Am I harming the engine by running it with this rattle or am I causing major damage? The car is off the road so its not doing anything other than idling and in a garage. My main objective is to get the car up and running so when I turn the key it starts and doesn't leak so much oil the car looks like its about to catch on fire. I am very new to this so please excuse me for not being very technical. Just trying to give this car a new lease of life. ![]()
aloha and welcome to the forum. when you say you put oil by the stick was the car running and warm? porsche's are dry sump engines. it might be overfilled now if not. "a rattle" is pretty vague to figure. if in the topend and regular with r's, probably valve adjustment. no pushrods on ohc engines. can be lotsa other stuff too. i use a stethascope sorta device to isolate sounds. do some research here and learn about your car. it has special needs but offers special rewards. good luck with it. cheers, geoff
I had a rattle, not terribly loud, decided to remove the valve covers for a valve adjust. A couple of broken head studs fell onto the shop floor. That was a crap day. Hope this is not your motor’s fate.
76 911S Targa
This forum can be your friend. Post pics of the bottom of the engine. Record and post the engine noise that worries you. Some smart person here will recognize it.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Welcome to the forum. I've found lots of help here.
I recommend not running the motor much until the source of the rattle is determined. Where are you located? Perhaps some local Pelican would be willing to pay a visit and offer an opinion. |
East Hampton, New York
Update
Thought I would share an update and a link to a video I made this weekend. Unfortunatley, not only do I have to deal with this "rattle" but looks like either the engine oil thermostat or oil pressure switch is leaking. I had an unbelievable amount of oil dropping from above the oil cooler onto the heat exchange. I've attached an image to where I believe the oil is coming from. I'm planning on dropping the engine a few inches this weekend so I can confirm thats where the link is coming from and to replace the parts.
I've uploaded the videos to vimeo and the password is: 911targa https://vimeo.com/album/5119943
Just to reconfirm - you are checking the oil level while the engine is running, correct?
'79 911SC Targa |
Don't run it anymore as mentioned,pull the rocker covers and sump plate and check for anything out of the norm, unfortunately the chance of broken head stubs is a strong possibility with the engine you have. I would not be to worried about the upper engine oil leaks @ this stage they are minor issue compared to the main problem you have,good luck and keep all posted what you find.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Functionista
Sound like a chain in a metal garbage can? At low to medium revs? Chain tensioner could be failing.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
76 911S Targa
When the engine oil is overfilled, the excess overflows into the air box. At the back of the airbox is a rubber tube that takes the overflow and drains it behind the oil cooler and onto the heat exchangers.
Speed Metal Army General
Here's a video of the sound: Password: 911targa |
| Tags |
| 911 , engine noise , push rod , rattle |
