Fuel Distributor RE installation help
Part 2... got the thing on which isn't easy with the engine in.
So now I can guess how the most of the lines hook up but there are a couple that I might be mistaken. Is there an order to the madness to connecting the fuel lines to the distributor? AND or... is it the same as an 80 SC which I have right beside this 81... the fuel lines are different but I guessing the connections are the same? ![]()
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
They are not sequential so you have plastic lines just hook up right and left.
Bruce |
Fuel lines from fuel distributor.........
This is the normal configuration of the fuel lines connections: Cylinder # 1..................C 2..................D 3..................E 4..................B 5..................A 6..................F Tony |
Thank you so much for the info!
