fender hex bolt under windshield??
Any ideas how to remove the hex bolt from inside the fender hidden in the back of the door jamb and windshield?? WITHOUT taking door off?
I'm having a problem getting enough pressure pushed onto the tool to hold it inside the bolt while turning it... its on rather tight.
You know... the more I'm working on this 911, the more I scratch my head at how poorly designed the car is.
1987 Porsche 911 Carrera Coupe
Old 04-20-2018, 06:40 AM
Slippery Slope Victim
NY65912's Avatar
¼" drive 10mm socket, either a flex type socket of a u joint attached, with a 6" extension. Make sure to seat the socket well on the head of the bolt. Also, add some tape to the leading edge of the door adjacent to the bolt. Your going to have to play with the correct angle to approach the bolt.
It's doable
Mike²
1985 M491
Old 04-20-2018, 06:46 AM
Home of the Whopper
Getting out is "easy".
Wait til you try to get it back in!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 04-20-2018, 07:25 AM
NY65912's Avatar
I place a piece of "dum-dum" inside the socket to hold on to the nut.
Mike²
1985 M491
Old 04-20-2018, 08:06 AM
dum-dum??? I have no idea what that is.
Old 04-20-2018, 08:07 AM
ugh... I may end up taking the door off when this happens.
Old 04-20-2018, 08:08 AM
NY65912's Avatar
Dum dum is pliable body, window caulking on a roll.
Mike²
1985 M491
Old 04-20-2018, 02:51 PM
pete3799's Avatar
You can remove and reinstall with the door on. Not easy but doable.
As mentioned 1/4 inch drive.
Pete
79 911SC RoW
Old 04-20-2018, 03:08 PM
proporsche's Avatar
trakrat ,why do you want to remove that particular bolt? You did not say.Are you replacing the fender seals?
if that is yes ,there is no need to remove competently..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-20-2018, 03:21 PM
Home of the Whopper
I use a short piece of flexible hose.
Squeeze the bolt head into the hose, then you can change the angle as you free spin the bolt to start.
You need to keep the door on to line up the fender.
Old 04-20-2018, 03:34 PM
1/4" ratchet, long extension and a 10mm wobbly socket. Not too hard.
206 637 4071
Old 04-20-2018, 04:07 PM
Ivan
I'm removing the entire fender... I have some rust I need to repair under the oil lines and at the bottom corner of wheel well by the door.
Old 04-21-2018, 10:21 AM
proporsche's Avatar
hi..i see now i understand;-) yup just get some swivel as peeps suggested above...
Ivan
Old 04-21-2018, 12:21 PM
what is a wobbly socket? I did a google search and found quite a few different tools that seems to come up... wanted to make sure I'm looking at the same thing you are referring to.
Old 04-26-2018, 10:05 AM
KTL KTL is offline
Schleprock
KTL's Avatar
You can buy an extension that is rounded at the male connecting end for the socket. It lets the socket wobble a bit to allow misalignment. Or you could use a 1/4" drive universal joint adapter
https://www.amazon.com/TEKTON-1660-Combination-Extension-9-Piece/dp/B000NPUJLW
https://www.homedepot.com/p/Husky-1-4-in-Drive-Universal-Joint-H4DUNIV/202911953
Kevin L
'86 Carrera "Larry"
Old 04-26-2018, 10:44 AM
206 637 4071
Old 04-26-2018, 11:07 AM
ok... I thought I would take a picture of the bolt in the upper inside fender.
the only way I could think of getting this off is to put enough pressure against the bolt to turn it... unfortunately a wobbly socket (picked one up) and a u-joint doesn't allow me to put force onto it.
I'm not sure if the bolt is somewhat stripped, if it is just too rusted on there, or a combination of both.
Would rather NOT take the door off, but at this point I'm at a loss.
Old 04-26-2018, 04:32 PM
An 87 uses a allen head bolt, not a hex head,,,,and that allen bolt appears to be rounded out.
Old 04-26-2018, 07:00 PM
glad I'm not the only one who thinks that.
Old 04-27-2018, 06:17 AM
grateful user
don gilbert's Avatar
Your door is coming off.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-27-2018, 06:50 AM
