-   -   Shift mark continued (http://forums.pelicanparts.com/porsche-911-technical-forum/994541-shift-mark-continued.html)
frosty2 04-24-2018 05:14 AM
http://forums.pelicanparts.com/uploa...1524571946.jpg
Sorry This photo may show the wear mark better
Mike
jpnovak 04-24-2018 06:49 AM
Are you referring to the wear mark in the middle of the clutch fork arm?
My guess is that the clutch pedal stop is set too low and the depressed clutch is slightly rubbing the outside edge of the pressure plate. Check the pressure plate corner for matching wear marks.
frosty2 04-24-2018 04:21 PM
Thanks jpnovak I will check that out there is a small rub mark on the outside of the pressure plate so I will check the pedal stop adjustment.
Mike
pmax 04-24-2018 04:46 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/994540-shift-fork-mark.html
