Missing spline for 3.2 Carrera steering wheel ?
Saw one for sale locally, so I thought it would be fun to refurbish a 3.2 Carrera steering wheel.
I will probably keep it as a spare. I always wanted to try an upholstery project, and this seems like a plausible first project. ![]() The wheel is missing the female spline part. I suspect it was transferred over to the aftermarket wheel. Anyone know where I can source the spline part?
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 04-08-2018 at 07:27 PM.. |
For comparison, below shows the splined part that is missing. Does someone make it?
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 04-20-2018 at 06:02 PM.. |
Never seen one advertised anywhere. I could use one too.
I think the owner transferred the spline for use with his aftermarket wheel.
Common to remove the spline and bolt it onto your Momo wheel? Momo Steering Wheel Install, Illustrated
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 04-20-2018 at 06:57 PM.. |
Looks like this was a wheel with a hub extension which is attached to the hub with 3 allen bolts. The extension part is not available individually so it's going to be difficult to complete the wheel.
Brgds Alex |
What Alex said above. You can swap a std non extended hub on it by drilling out the 4 rivets.
If you drill out the 4 rivets, how do you re-attach a standard hub (with spline)?
Are standard hubs commonly sold?
1986 Bosch Icon Wipers coupe. |
You try and find a std non extended hub froma a worn out wheel.
Hubs, std or extended are not available as spare parts from Porsche. |
Counterclockwise?
If you could buy the hub it would be nice as there are so many 924/928/944 wheels out there that no one wants.
I'm not sure I understand your logic.
What does this have to do with 924/928/944 steering wheels?
I might have an extra one, give me a day or so.
Counterclockwise?
First I've ever heard of this.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Big thanks to SWS911 for sending me a regular steering wheel crush tube hub with spline.
![]() I'll swap this one onto the wheel Just need to figure out the nest method to remove those rivet heads. Then get 4 high strength bolts and use red Loctite
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 04-29-2018 at 10:08 AM.. |
@_more_momo
I will remove my current wheel and compare.
What is the clue you are seeing?
Good call.
It does not fit. Diameter is too large
@_more_momo
Oh i didn't have a real clue. I was just interested in finding out about the make and model since i kind of like how it looked. Nothing more really... :-)
Pull back the rubber cover and your car also has that.
