sugarwood's Avatar
Missing spline for 3.2 Carrera steering wheel ?
Saw one for sale locally, so I thought it would be fun to refurbish a 3.2 Carrera steering wheel.
I will probably keep it as a spare.
I always wanted to try an upholstery project,
and this seems like a plausible first project.
The wheel is missing the female spline part.
I suspect it was transferred over to the aftermarket wheel.
Anyone know where I can source the spline part?
1986 Bosch Icon Wipers coupe.
Old 04-08-2018, 07:05 PM
sugarwood's Avatar
For comparison, below shows the splined part that is missing. Does someone make it?
Old 04-20-2018, 05:58 PM
Never seen one advertised anywhere. I could use one too.
206 637 4071
Old 04-20-2018, 06:01 PM
sugarwood's Avatar
I think the owner transferred the spline for use with his aftermarket wheel.
Common to remove the spline and bolt it onto your Momo wheel?
Momo Steering Wheel Install, Illustrated
Old 04-20-2018, 06:52 PM
Looks like this was a wheel with a hub extension which is attached to the hub with 3 allen bolts. The extension part is not available individually so it's going to be difficult to complete the wheel.
Brgds
Alex
Old 04-21-2018, 12:43 PM
What Alex said above. You can swap a std non extended hub on it by drilling out the 4 rivets.
Old 04-21-2018, 01:09 PM
sugarwood's Avatar
If you drill out the 4 rivets, how do you re-attach a standard hub (with spline)?
Are standard hubs commonly sold?
Old 04-21-2018, 04:48 PM
You try and find a std non extended hub froma a worn out wheel.
Hubs, std or extended are not available as spare parts from Porsche.
Old 04-21-2018, 11:08 PM
Counterclockwise?
If you could buy the hub it would be nice as there are so many 924/928/944 wheels out there that no one wants.
Old 04-22-2018, 11:30 AM
sugarwood's Avatar
I'm not sure I understand your logic.
What does this have to do with 924/928/944 steering wheels?
Old 04-24-2018, 03:17 AM
I might have an extra one, give me a day or so.
Old 04-24-2018, 04:46 AM
I sold a 1982 928 four spoke wheel to a SC owner. The wheel fitted his car, so they must be swappable.
Old 04-24-2018, 05:06 AM
Counterclockwise?
First I've ever heard of this.
Rod
1986 Carrera
2001 996TT
Old 04-24-2018, 06:13 AM
sugarwood's Avatar
Big thanks to SWS911 for sending me a regular steering wheel crush tube hub with spline.
I'll swap this one onto the wheel
Just need to figure out the nest method to remove those rivet heads.
Then get 4 high strength bolts and use red Loctite
Old 04-29-2018, 09:46 AM
@_more_momo
Outlaw_singer's Avatar
That hub fits a 911? I'd love to know more about that...
Old 04-29-2018, 10:32 AM
sugarwood's Avatar
I will remove my current wheel and compare.
What is the clue you are seeing?
Old 04-29-2018, 12:00 PM
sugarwood's Avatar
Good call.
It does not fit.
Diameter is too large
Old 04-29-2018, 01:55 PM
@_more_momo
Oh i didn't have a real clue. I was just interested in finding out about the make and model since i kind of like how it looked. Nothing more really... :-)
Old 04-29-2018, 02:21 PM
sugarwood's Avatar
Pull back the rubber cover and your car also has that.
Old 04-29-2018, 04:18 PM
