Rotor Replacement
I am replacing my rotors on an 84 911 with upgraded turbo calipers. This is a dedicated DE car.
I have run VCI rotors for the past two years but was curious if there was another brand/mfg. that someone might recommend. I am running Pagid Yellows. Car weighs 2200 lb. without the driver....3.6 converbsion. Thanks! |
Schleprock
Which size VCI/Coleman rotors are you using, the 12 in. or 12.75? I and some others have used the Wilwood HD or Wilwood GT 12.19 in. x 1.25 in. rotors with excellent results. Wilwood makes a rotor in both sizes to mimic the VCI rotors. However your VCI hats won't bolt up to the Wilwood rotors. So you'll need to have new hats made.
Kevin L '86 Carrera "Larry" |
tHE 12.75". They are the VCI model #3001 and are non-floating.
Schleprock
The Wilwood GT 48V is the one you could use in either of the sizes listed below. There are four rotors because they are directional.
Thanks!
I appreciate the help. I will check them out.
| Tags |
| brake rotors , racing rotors |
