fmcolorado
Ignition Timing
I have a 1973.5 911T with 2.4/CIS. Ignition uses CDI and I have replaced the original points with a Pertronics magnetic pickup. I live at an altitude of 5000 feet. Should I change the timing from spec to account for altitude.
You can definitely add a degree or two above stock at altitude.
No physical quantity completely explains its own existence |
