-   -   9" rears with RSR flares? (http://forums.pelicanparts.com/porsche-911-technical-forum/996048-9-rears-rsr-flares.html)
VadGTI 05-09-2018 12:08 AM
I'm looking at possibly purchasing a car with RSR/Turbo flares. It currently has terrible 18" wheels. I'm looking at Euromeister 16 (or possibly 17) x9" for the rear. I've searched the various forums and still can't figure out if this would work (I understand true RSRs were 11" rears) and what it would look like. Am I wrong in thinking a 9" would work?
RarlyL8 05-09-2018 05:56 AM
9 x 16 or 17 Euromeisters would fit 11" flares with spacers. How thick the spacer needs to be depends on if the suspension is 911 or 930.
nathanbs 05-09-2018 06:12 AM
Are you sure they are not RS flares. Those are ideally 8”s but can squeeze certain 9” wheel and tire combos. 9”s on RSR flares which are more similar if not identical to turbo flares would look funny
darrin 05-09-2018 06:15 AM
keep in mind that tire options are VERY limited for the 245/45-16 size needed for the 16x9 -- a lot more options available in the 225/50-16 size that fits 16x8 rears.
faverymi 05-09-2018 06:19 AM
Rota is making rsr finish 11x17
The will look wicked w your rsr flares for cheap.
VadGTI 05-09-2018 07:36 AM
I can't find any reference to this anywhere. Do you have a link? All I'm seeing is 9" for the Rotas.
This is the look I'm trying to avoid (Rota 9" rears):
https://rennlist.com/forums/attachme...416_102058.jpg
Duc Hunter 05-09-2018 07:46 AM
My 911 Rat Rod with 7" front and 9"rear Euromiester's, and spacers.
http://www.pbase.com/mrcjb60290/image/165176155.jpg
VadGTI 05-09-2018 10:27 AM
Chris, are those 17"s?
Duc Hunter 05-09-2018 12:09 PM
Yes they are, Euromeister's. 255/40/17 rear. 225/45/17 front.
brasch 05-09-2018 02:02 PM
http://forums.pelicanparts.com/uploa...1525897662.jpg
Tremelune 05-10-2018 11:07 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/991282-wheels-spacers-hubs-offsets.html
I'd go with 8x16 or 17s in the rear for tire selection and lightness. Both 16x9 and 16x8 Fuchs would use spacers in the rear for 930 flares. I think the difference on the outside is like 4mm because most of the width of the 9" wheel is gained on the inside.
VadGTI 05-10-2018 11:19 PM
I found something about the need for 54mm spacers with 16x9 Euromeisters. I can't find any such spacers for sale. I found one site that used to carry them but lists them as "no longer available." What spacers are people using with these?
panzerfaust 05-11-2018 08:14 AM
cool track rat... which company made your front bumper?
safe 05-12-2018 01:03 PM
You can get custom spacers made. Not sure where were you live.
On turbo/rsr flares 9 and 11 fits and looks nice!
BUT, I would check availibility of tires, preferbly good tires, before choosing rims. There are options for wide 15" and wide 18", but few for 16 and 17.
faverymi 05-12-2018 01:08 PM
Vad GTI
Here is the info, I guess you have to go to wheeldude directly
http://forums.pelicanparts.com/porsche-911-technical-forum/987785-test-fitted-some-used-rubber-rota-11x17s-9x17s.html
faverymi 05-12-2018 01:10 PM
I would recommend to stay with 17 wheels because of tire availability
16 are almost extinct in good rubber.
My wide body runs custom CCW for this reason
Bill Verburg 05-12-2018 03:35 PM
Unless you go crazy w/ tires 8 & 9 or 9.5 17s can compare well w/ 7 & 8 x16 fuchs
245/40 x17 is only a little taller and heavier than a 245/45 x16
http://forums.pelicanparts.com/uploa...1526164395.gif
You're still going to need large spacers w/ 930 flares
VadGTI 05-15-2018 09:27 PM
11" wheels seem to be pretty pricey compared to Euromeisters, the widest of which seems to be 9".
This is the look I want to achieve if everything works out. The ad for this car claimed these were 17x8 and 17x9, but they seem to sit perfectly somehow:
https://s13252.pcdn.co/wp-content/up...4.34.24-PM.png
https://s13252.pcdn.co/wp-content/up...-GC.com-38.jpg
https://s13252.pcdn.co/wp-content/up...-GC.com-26.jpg
There's clearly some sort of a spacer on there:
https://bringatrailer.com/wp-content...-GC.com-93.jpg
Speed metal 05-15-2018 09:53 PM
11x17 and 9x 17 rotas.
http://forums.pelicanparts.com/uploa...1526445328.JPG
The 9's never quite fill up the rear.
VadGTI 05-16-2018 04:07 PM
Are these Rotas still made? I can't find them anywhere.
