9" rears with RSR flares?
I'm looking at possibly purchasing a car with RSR/Turbo flares. It currently has terrible 18" wheels. I'm looking at Euromeister 16 (or possibly 17) x9" for the rear. I've searched the various forums and still can't figure out if this would work (I understand true RSRs were 11" rears) and what it would look like. Am I wrong in thinking a 9" would work?
Old 05-09-2018, 12:08 AM
Crotchety Old Bastard
RarlyL8's Avatar
9 x 16 or 17 Euromeisters would fit 11" flares with spacers. How thick the spacer needs to be depends on if the suspension is 911 or 930.
Old 05-09-2018, 05:56 AM
Are you sure they are not RS flares. Those are ideally 8”s but can squeeze certain 9” wheel and tire combos. 9”s on RSR flares which are more similar if not identical to turbo flares would look funny
Old 05-09-2018, 06:12 AM
keep in mind that tire options are VERY limited for the 245/45-16 size needed for the 16x9 -- a lot more options available in the 225/50-16 size that fits 16x8 rears.
Old 05-09-2018, 06:15 AM
faverymi's Avatar
Rota is making rsr finish 11x17
The will look wicked w your rsr flares for cheap.
Old 05-09-2018, 06:19 AM
I can't find any reference to this anywhere. Do you have a link? All I'm seeing is 9" for the Rotas.
This is the look I'm trying to avoid (Rota 9" rears):
Old 05-09-2018, 07:36 AM
My 911 Rat Rod with 7" front and 9"rear Euromiester's, and spacers.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-09-2018, 07:46 AM
Chris, are those 17"s?
Old 05-09-2018, 10:27 AM
Yes they are, Euromeister's. 255/40/17 rear. 225/45/17 front.
Old 05-09-2018, 12:09 PM
Ächtung Kraft Founder - Custom Porsche Parts and Leather
http://achtungkraft.com - Bryan Rasch - bryan@achtungkraft.com
INSTAGRAM // @AchtungKraft // @BrightonRennsport
1972 911 ROW Steel Wide body Outlaw w/'86 turbo drivetrain
1976 911S + 2006 911 4S + 2009 Cayenne GTS + 1988 944
Old 05-09-2018, 02:02 PM
Eng-o-neer
Tremelune's Avatar
Wheels, spacers, hubs, offsets...
I'd go with 8x16 or 17s in the rear for tire selection and lightness. Both 16x9 and 16x8 Fuchs would use spacers in the rear for 930 flares. I think the difference on the outside is like 4mm because most of the width of the 9" wheel is gained on the inside.
Old 05-10-2018, 11:07 PM
I found something about the need for 54mm spacers with 16x9 Euromeisters. I can't find any such spacers for sale. I found one site that used to carry them but lists them as "no longer available." What spacers are people using with these?
Old 05-10-2018, 11:19 PM
cool track rat... which company made your front bumper?
Old 05-11-2018, 08:14 AM
safe's Avatar
You can get custom spacers made. Not sure where were you live.
On turbo/rsr flares 9 and 11 fits and looks nice!
BUT, I would check availibility of tires, preferbly good tires, before choosing rims. There are options for wide 15" and wide 18", but few for 16 and 17.
Magnus
Old 05-12-2018, 01:03 PM
faverymi's Avatar
Vad GTI
Here is the info, I guess you have to go to wheeldude directly
Test fitted some used rubber on the Rota 11x17's and 9x17's
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 05-12-2018, 01:08 PM
faverymi's Avatar
I would recommend to stay with 17 wheels because of tire availability
16 are almost extinct in good rubber.
My wide body runs custom CCW for this reason
Carrera Luigi CDtdi
Old 05-12-2018, 01:10 PM
Bill Verburg's Avatar
Unless you go crazy w/ tires 8 & 9 or 9.5 17s can compare well w/ 7 & 8 x16 fuchs
245/40 x17 is only a little taller and heavier than a 245/45 x16
You're still going to need large spacers w/ 930 flares
Bill Verburg
Old 05-12-2018, 03:35 PM
11" wheels seem to be pretty pricey compared to Euromeisters, the widest of which seems to be 9".
This is the look I want to achieve if everything works out. The ad for this car claimed these were 17x8 and 17x9, but they seem to sit perfectly somehow:
There's clearly some sort of a spacer on there:
Old 05-15-2018, 09:27 PM
Speed Metal Army General
11x17 and 9x 17 rotas.
The 9's never quite fill up the rear.
Old 05-15-2018, 09:53 PM
Are these Rotas still made? I can't find them anywhere.
Old 05-16-2018, 04:07 PM
