Earthling
SSI heat exchangers -what’s the port for?.
Overhauling wife’s 79SC and just installed the SSI heat exchangers and Dansk 2->1 mufflet, wow just beautiful.
But not sure what the little port (circled in red) is for or what I should do with it. Can’t find anything with a search but maybe using the wrong terms. Guessing it might be there for later lambda cars, if so I assume I should cap it off? If so, how? There’s a rubber cap in place now, i assume it would melt in short order. TIA/Brian
1996 Porsche 993 C4. His 1979 Porsche 911SC - sold... and now BACK again! Hers 2021 Volvo V60 (foul weather drive) 2024 Volvo XC60 (spousemobile) |
I would rather be driving
That is for the warm up hose on 69-71 MFI cars. You can cap it off.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Earthling
Thanks Jamie, i figured it was something like that but not sure which year(s) applied.
Any suggestions what to use for a cap? If exhaust gases are going through there I assume it’ll get too hot for a rubber bung or clamped-off hose Thx/Brian
Just hot air, no exhaust gas.
Earthling
Thanks John.
In that case I’ll use whatever works on politicians...
Coram Deo
If you figure that out, you'll be a hero to all of us!
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Earthling
So I figured it would have to be heat resistant, so I googled “silicone plug” and this came up. This should work on politicians too, no?
That's very funny
It will be interesting to see how you find how the characteristics of the engine have changed. My '79 has SSis but I swapped out the engine for an engine that already had the SSIs. So I can't really compare. Nice to lose a few Kg's off the arse end of the car too.
Those are the "wrong" part for your car. They do make the correct part without the MFI heater tube.
