-   -   Another Help Identify Wiring Question (http://forums.pelicanparts.com/porsche-911-technical-forum/996369-another-help-identify-wiring-question.html)
petercory 05-12-2018 08:53 AM
Need help to identify 2 wires attached to an unusual looking connector/plug hanging down below dash on the right side of the steering column; 1 wire is Violet, the other is black.[/B]http://forums.pelicanparts.com/uploa...1526139988.JPG
rwest 05-12-2018 09:21 AM
If my memory is correct, it connects to the ignition switch body to make an annoying sound if you leave the key in the ignition and open the door. Mine was originally disconnected, so I connected it and then disconnected it again!
steely 05-12-2018 09:49 AM
+1 - sure looks like that's what it is. The Violet wire is tied-to/involved with the Seat belt control unit which also buzzes.
http://forums.pelicanparts.com/uploa...1526143758.JPG
petercory 05-12-2018 10:04 AM
Thanks for the help; it's greatly appreciated!
