petercory
Another Help Identify Wiring Question
Need help to identify 2 wires attached to an unusual looking connector/plug hanging down below dash on the right side of the steering column; 1 wire is Violet, the other is black.[/B]
Old 05-12-2018, 08:53 AM
If my memory is correct, it connects to the ignition switch body to make an annoying sound if you leave the key in the ignition and open the door. Mine was originally disconnected, so I connected it and then disconnected it again!
Rutager West
Old 05-12-2018, 09:21 AM
steely's Avatar
+1 - sure looks like that's what it is. The Violet wire is tied-to/involved with the Seat belt control unit which also buzzes.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-12-2018, 09:49 AM
petercory
Thanks for the help; it's greatly appreciated!
Old 05-12-2018, 10:04 AM
