-   -   Setting Points on a 72 2.4 (http://forums.pelicanparts.com/porsche-911-technical-forum/99642-setting-points-72-2-4-a.html)
IAN 02-25-2003 09:11 AM
Do I only need to set the Gap on points?
Or do I need to use a dwell meter?
I was going to keep timing where it is, as it was just set but I would like to replace my points.
Will I notice a difference with new points?
Thanks.
tryan 02-25-2003 09:20 AM
carefull with the dwell meter. the cd box willl be damaged if you hook up wrong. i just set mine with a feeler and go on.
