Anyone have a pic of the fuel rail....
....where the "service port" is? I need to access on my 85 911 for a fuel tank drain.
If someone could post the pic I'd really appreciate it. Regards, Rick |
Irrationally exuberant
If you are talking about the testing port where you put your fuel pressure guage, it's on the left side fuel rail, on the end closest to the back of the car. It may be hidden behind the heater blower downtube.
Under the cap is a little ball that seals the hole. Be careful not to loose it when removing the cap. -Chris |
Chris, Thanks for the tip I thought it had a tire valve type fitting......Rick
Warren & Ron, may you rest in Peace. |
If some still has a pic I'd surely appreciate it. Thanks again.
