After the next project
need help identifying bracket and location for vacuum line 87' Carrera
I am in the middle of putting my motor back together after a rebuild and I've come across this bracket where I cannot seem to find where it would attach to and what it is for... it's in the engine compartment or on the engine somewhere...
Additionally, I found this vacuum line along the rear firewall of the car. It comes out by the cruise control module but runs along the rear of the car and eventually goes through the fender out to the charcoal/emissions canister in the right side wheel well. Any idea where this connects to? The line next to it in the photo comes from the cruise control module and attaches into that vacuum line in a "T" style connection as you can see in the pic. Thanks for any help that you can offer! I didn't take a pic of this bracket or line anywhere so having trouble figuring out where these go... I can't find any vacuum hookup on the motor where this would attach. ![]() ![]()
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
this bracket goes behind the -under the -left side -heater motor to hold the el.harness ..let me look for pics.the little hose goes on you cruise control drum behind the bigger hose -on picture you can see the niple...
here in the middle is the bracket
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Red Line Service
The bracket is for the spark plug wires, above cylinder #1
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
i have all those
I have those brackets in place.
The hose is already taken up by the hose that you see below which attaches into the "T" vacuum lines which go to the motor. ![]() ![]() ![]() ![]() It may come off under the heater motor but need a pic to see it better, can't seem to locate where it would go. Thanks for helping!
lake wales fla
Richard |
Okay, I will have a look at my photos, it must be there but just missing it. I understand you're thinking first shroud bolt on the last photo from mine above that you can see just above the upper valve cover.
Any idea for those on the vacuum line? Thanks!!
Thanks Marc!
marc.is correct;-) silly me.....
Ivan
Update: Vacuum line dives down behind left side rear shock tower and through the tunnel. It's the line which connects the charcoal canister to the gas vent up front.
Thanks for all the help.
