Looking for Advice: 1977 Targa Oil Leak
Hi,
I picked up my 1977 911 Targa about 6 weeks ago and have been driving it somewhat regularly with the nice weather. j
I noticed a few weeks back that was a bit of oil on my garage floor so I placed some cardboard under the engine and sure enough, when I return home from a drive, there is some oil.
I'm quite new to the 911 and would appreciate some advice or suggestions on how I can diagnose this issue.
It appears the oil is leaking down from the passenger side header/muffler area. I'll post some pics in a bit.
Old 05-21-2018, 02:09 PM
Old 05-21-2018, 02:28 PM
Oil leaks are like roof leaks, hard to determine where the actual source is as it migrates around.
Below is the thread I had on one of mine, leaked long before I could track it down and became bad enough to notice the spray/leak source.
Oil Leak - Take a Look
Old 05-21-2018, 02:53 PM
Thanks for the link
Old 05-21-2018, 03:51 PM
7783911's Avatar
Kachi
In you link I am not sure what your pointing to..the small smudge on the vertical component or at the bolt to the left of that..i am curious because i removed the AC as well and need to know what to check to ensure all is ok?
Old 05-21-2018, 06:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
OP, start by washing the engine then use mirrors to see where it coming from.
Your pics are basically where it is ending up.
Has the engine ever been top ended or rebuilt?
'85 Carrera Targa
PCA/POC
Old 05-21-2018, 10:49 PM
Originally Posted by DRACO A5OG View Post
OP, start by washing the engine.........
Yes, that is how I found my fresh oil leak, had to clean the engine first.
I answered your PM "7783911", first photo, top large circled area, biggest complete bolt head in the yellow circle was the leak source. The other bolt head in that photo is just a cover plate bolt.
Oil sending unit possibly leaking was a suggestion to look into John Walker's Shop made in that thread. I would it assume it applies to your situation as well, good luck.
Old 05-22-2018, 12:57 AM
Thanks for the tip, I'll give it a wash and then start looking for the leak,
Cheers!
Old 05-22-2018, 08:24 AM
KMoore68,
I'm surprised nobody has mentioned having too much oil. These mid years expel any excess oil into the airbox. At the bottom of the airbox is a drain. Porsche has carefully engineered this drain to empty onto the passenger side exhaust.
Remove your air filter and see if you have oil on the bottom of the airbox. If you do, don't fill the oil as far up the dip stick. About half way or less is about right.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 05-22-2018, 03:59 PM
