My TRE '74-'89 911 front bumper solution... more for protection at my drive way approach.
Plywood templet made. http://forums.pelicanparts.com/uploa...1542717581.jpg More pic's herer----->http://forums.pelicanparts.com/porsche-911-technical-forum/1002364-85-outlaw-build-thread.html |
http://forums.pelicanparts.com/uploa...1542722359.jpg
I made my own - it was pretty easy to take off and put on |
Ag,
very nice .What material did you use . I have a ME in the family and he suggests : CF e-panel hydrotek dibond can you advise dims' you used and how you attached it . I have the same rsr valence . |
I just took my bumper off, put it down on a piece of 1/8” plywood and traced the bottom of the bumper onto it. Then used a compass to extend it 2.5”, plus a bit more in front of the cooler opening. I made 3 of the plywood splitters, one I’ll use as a pattern for a piece of aluminum to try, and one I’ll ‘glass over to try and make pretty. This is a track car so show quality isn’t critical.
http://forums.pelicanparts.com/uploa...1542799323.jpg |
Material is 2024 aluminum at .125 thickness roughly. It is bolted in about nine places to the bottom lip of the TRE lower facia. I am also a ME/SE. I made my own pattern from plywood so that I could shape what I wanted. I transferred that shape to the aluminum sheet, cut it out and sanded. Then I did my own finishing. |
AG,175,
Great ideas, thank you. Front bumper is coming off before Turkey time tomorrow. I'de go crazy if I didn't have winter projects to work on. |
Here’s mine all finished with a bit if proper damage.
http://forums.pelicanparts.com/uploa...1558058408.jpg http://forums.pelicanparts.com/uploa...1558058408.jpg http://forums.pelicanparts.com/uploa...1558058408.jpg |
These are great, anyone have info on that orange car, with the integrated tow hook? Where/how would you mount that hook?
| All times are GMT -8. The time now is 04:35 PM. |
