-   -   Ignition switch rebuilder (http://forums.pelicanparts.com/porsche-911-technical-forum/997383-ignition-switch-rebuilder.html)
930cabman 05-23-2018 03:30 AM
Our 1975 911 is currently being started with a Phillips head screwdriver, but don't tell anybody. It appears the mechanical portion does not rotate enough to engage the contacts within the electrical portion of the switch. I suspect something is worn inside the mechanical portion. Is there anybody out there that rebuilds these?
tirwin 05-23-2018 04:54 AM
Your post gave me a laugh only because that’s exactly how I started my car when I bought it. PO had the same problem. The screwdriver came with the car as part of the deal. It was the mechanical portion as you suspect.
I vaguely remember reading some posts with proposed fixes that didn’t work for me. In my case I replaced the ignition lock assembly. Not a fun project. You have to drill out the 2 shear bolts and remove the driver seat so you can work on your back and contorted.
If you get a new one and want to keep one key for the car you’ll have to re-key the tumbler on the new assembly.
Dpmulvan 05-23-2018 05:16 AM
I can fix it, I also have extra ignitions for sale which I can rekey to match your car.
You don't need to drill out bolts simply take a small sharp chisel and hammer from the 6 o'clock
position towards the 3 o'clock position this will loosen bolts.
tirwin 05-23-2018 05:40 AM
That’s right, you don’t need to drill them out. I think I did end up cutting a slot in one with a dremel so I could get better purchase.
mepstein 05-23-2018 06:07 AM
"Tweet" on this site can rebuild and rekey to new specs. He's done work for me and I've been very pleased every time.
Harpo 05-23-2018 09:13 AM
I was not aware that ignition switches can be rebuilt
