Ignition switch rebuilder
Our 1975 911 is currently being started with a Phillips head screwdriver, but don't tell anybody. It appears the mechanical portion does not rotate enough to engage the contacts within the electrical portion of the switch. I suspect something is worn inside the mechanical portion. Is there anybody out there that rebuilds these?
El Duderino
Your post gave me a laugh only because that’s exactly how I started my car when I bought it. PO had the same problem. The screwdriver came with the car as part of the deal. It was the mechanical portion as you suspect.
I vaguely remember reading some posts with proposed fixes that didn’t work for me. In my case I replaced the ignition lock assembly. Not a fun project. You have to drill out the 2 shear bolts and remove the driver seat so you can work on your back and contorted. If you get a new one and want to keep one key for the car you’ll have to re-key the tumbler on the new assembly.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
I can fix it, I also have extra ignitions for sale which I can rekey to match your car.
You don't need to drill out bolts simply take a small sharp chisel and hammer from the 6 o'clock position towards the 3 o'clock position this will loosen bolts. |
El Duderino
That’s right, you don’t need to drill them out. I think I did end up cutting a slot in one with a dremel so I could get better purchase.
The 9 Store
"Tweet" on this site can rebuild and rekey to new specs. He's done work for me and I've been very pleased every time.
All used parts sold as is. |
I was not aware that ignition switches can be rebuilt
David |
