flatsixguy's Avatar
Mystery wire ??
Hi Gentleman
Just did my first engine drop to clean up a few annoying leaks on my 1980SC US spec.
The cold start valve has 3 wires coming out of it, 2 go to the thermal switch mounted in the left chain case but the Yellow with Blue stipe is puzzling me any ideas??
maybe starter relay/solenoid??
cheers
Michael
Old 05-23-2018, 09:20 PM
ROW '78 911 Targa
timmy2's Avatar
Terminal 16 on the starter solenoid.
Used to energize the entire CSV and TTS circuit
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-23-2018, 10:06 PM
flatsixguy's Avatar
thanks Dennis
Old 05-23-2018, 11:08 PM
flatsixguy's Avatar
another wire I'm trying to work out is the BLUE coming off the small 6 pin harness that has the throttle position switch and two other plugs on it.x
thanks in advance
Michael
Old 05-23-2018, 11:59 PM
ROW '78 911 Targa
timmy2's Avatar
Likely the temp sensor on the right chain case. (If it is long and a single connector on the end)
Dennis
Old 05-24-2018, 07:59 AM
flatsixguy's Avatar
This is the loom in question? link attached below (hopefully it works) my engine doesn't seem to have any sensors on the right chain case Dennis
https://www.dropbox.com/s/rfyo9v3aewbseyf/IMG_1607.JPG?dl=0
Old 05-24-2018, 08:56 AM
ROW '78 911 Targa
timmy2's Avatar
That is the wire to the passenger side chain case temperature sender.
Should be in same mounting area as the TTS sender on Driver’s side.
To post photos click go advanced then scroll down to “click here to upload photos and follow instructions.
Screenshot:
Dennis
Old 05-24-2018, 09:40 AM
flatsixguy's Avatar
hmm mine is blanked out with a large bolt on that side photo attached thx for the tip do some models come without this sensor?
Old 05-24-2018, 09:53 AM
That’s part of the lambda sensor system under the passenger seat.
Bruce
Old 05-24-2018, 09:57 AM
flatsixguy's Avatar
cheers Bruce, so where will i need to connect the ring terminal on this blue wire ?
Old 05-24-2018, 10:11 AM
ROW '78 911 Targa
timmy2's Avatar
Your picture.
Dennis
Old 05-24-2018, 10:56 AM
ROW '78 911 Targa
timmy2's Avatar
That wire connects to the missing sensor on your chain case.
The 6 pin connector plugs into the female plug on the top left area in the engine compartment above the torsion bar. From there it runs to the Lambda box under your seat.
All Euro and ‘78/‘79 US models did not have Lambda, so not used on those.
Dennis
Old 05-24-2018, 10:58 AM
flatsixguy's Avatar
really appreciate all this info, so should i reinstall this harness back and just not worry about the missing sensor and connection?
Old 05-24-2018, 11:51 AM
ROW '78 911 Targa
timmy2's Avatar
It is a temperature switch for controlling mixture until it warns up to a certain temp.
That is about all I know about it.
If it were me, I’d ditch all of it (CIS) and install EFI...
Oh yeah, I already did that 7 years ago....
Dennis
Old 05-24-2018, 12:43 PM
flatsixguy's Avatar
i think eventually that will be the path l take ..
Old 05-25-2018, 04:16 AM
