I have been told that a thach has to match the distributor, so when I got mine, it was from a 911L since I was using a 911L dist. (Bosch). That ended up needing to be replaced, and I now have a Bosch T dist. to match my 2.2T eng. Will my L tach work, or do I need a new tach for the T dist.? Since the car isn't running at the moment, I can't test anyway, but if anyone knows, then I can deal with this in the process.
Thanks! Daniel |
it will work with both, if it works.
