Removing master cylinder problem
I am replacing my master cylinder and rebuilding all four brake calipers on my 1972 911T. I have finished all of the calipers but I am struggling to get the master cylinder off. I got the three brake lines off using a flared 11mm wrench. I can’t figure out how to detach the two top lines as there is no visible nut only a rubber cover. These lines appear to go to the fluid reservoir.
Any help? I apologize for the poor pic. |
Coldstart,
Those are just a force fit. They just pull out. Part #: 901-355-929-00-M4 They can be difficult to get back in. I go in from a slight angle, rather trying to push them straight in. |
Thanks. I thought so but I didn't want to force it.
Great handle name. I enjoyed that movie and good pun. |
Clamp some large long nose visegrips on the tube and knock them upward with your palm. Same for install, but pull them in.
| All times are GMT -8. The time now is 10:36 PM. |
