boyo's Avatar
Anyone converted a 911 to propane/LPG?
Just one of those curious crazy thoughts. I had a truck back in high school that could switch between gas and propane, and I was wondering if it's been done for a 911.
(Not seriously considering it, just a curious kind of guy...)
Better have some "2.4P" grille badges made up...
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '72 Porsche 911T
Old 02-26-2003, 12:55 PM
Bird. It's the word...
Fishcop's Avatar
Good God Man, WHY!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 02-26-2003, 02:41 PM
Glasgow 911SC's Avatar
Dont know if its available over there but in the UK you can do a LPG (liquid petroleum gas) conversion which I guess is similar to the propane setup. The car gets the same power & mpg and the pollution is less. The conversion is a couple of thousand ish £'s. The fuel costs way less as well as there is less (or no?) tax added. The tax brake has only been gaurenteed for a few years though which is off putting.
BTW, I pay 82pence per litre at my gas station. Thats about $5.20 per US gallon!
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 02-26-2003, 02:48 PM
Thread Killer
Teutonics's Avatar
It's LPG, not CNG/propane (or a Porsche for that matter), but check the second car/article from the top on this page:
http://www.bmw2002.co.uk/racecars.htm
200+ HP and 185 lb./ft. out of a two-liter SOHC four cylinder..... not bad.
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 02-26-2003, 03:16 PM
disband
juanbenae's Avatar
curiuosly killed the cat,,, for good reason
Old 02-26-2003, 03:23 PM
Where would you put the tank?
Believe it or not, I had a Datsun B210 that had been converted to run on LPG once upon a time. At $1.50 per gallon of gas vs. $.75 for LPG at the time, it made economic sense.
That thing was heavy though. Had to beef up the rear suspension to support the 26 gallon steel tank. Then there's the fun of driving around with 26 gallons of LPG up your behind. I got rear-ended on the f'way in that thing one Thanksgiving morning - thank gawd for that quarter-inch steel tank. I promptly had the necessary cosmetic bodywork done and gave the car to my sister to drive for a few years!
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 02-26-2003, 03:58 PM
boyo's Avatar
There are some interesting upsides... Running at 12:1 compression for instance (octane equivalent of 144?)
You need some form of heating to keep the LPG expansion tank from freezing up where the liquid turns to gas. Normally there's a water loop from the car cooling system.
Conversely, when using a turbo- or super-charger, you should use some form of cooling to get better air density and reduce detonation. With the right kind of heat exhanger, both problems solved.
And last, but not least, maybe it could be used as cheap air conditioning!
-Boyo
Old 02-27-2003, 04:02 PM
Buy them, sell them
Adam's Avatar
I would have thought that the combustion temperatures from CNG/LPG would be far too high and damaging to the (sometimes tender) alloys used in 911 engines.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 02-27-2003, 04:04 PM
canna change law physics
red-beard's Avatar
CNG and LPG burn with _lower_ temps and less radiance than liquid petroleum fuels.....
These fuels would be much better fuels for the enviorment and for our cars than gasoline....
Metering a gas vs a liquid is always a challenge...
James
James
Red-beard for President, 2020
Old 02-27-2003, 05:05 PM
Buy them, sell them
Adam's Avatar
Oops! I was sure it was hotter... Even still, Petroleum Gasoline has a lubricant built into it, which LPG/CNG cannot deliver. You'd need to protect your valves and valve seats or modify them for LPG.
Old 02-27-2003, 05:51 PM
red-beard's Avatar
Actually, Gasoline has virtually no lubricating properties. Diesel does.
James
James
Old 02-27-2003, 06:21 PM
I use to see a bright yellow 935 bodied mid 70's 911 car that ran on LPG. It had some monster turbo motor in it.
I worked at a neighborhood gas station as a poor college student around 1990. The car would drive by occassionally and the owner stopped by for gas with his regular cars. That turbo made all the right noises. Your post brough up that memory. Have not seen that car in a while.
Tinker
Old 02-27-2003, 06:43 PM
Senior Member
Jdub's Avatar
My car smells of brimstone since I converted it to run on the flaming flatus of the devil's hindquarters. Had to trade my soul but He threw in chain tensioners and 9" fuchs...
John
'78 Targa in Minerva Blue
Old 02-28-2003, 06:21 AM
