what fuel pump
I have decided to replace the fuel pump, the fuel check valve and the hoses on my car.
From day one the pump is very loud i can hear it over everything, it is mounted nicely with rubber it is just one loud device.
I want a new one.
What are my choices here? I think mine is factory unit.
Thank you.
1974 911 coupe 4 speed
Old 06-03-2018, 12:39 PM
Is it loud enough to hear over the engine running noise?
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 06-03-2018, 01:05 PM
High Life's Avatar
I want a new one.
Thank you.
I just replaced mine a couple of days ago. I went with BOSCH - bought it off Amazon real cheap $139 (included tax and 2 days shipping). The one I replaced was also the same unit. I have a 1981 911SC - I purchased Bosch 69466
Mine started humming real loud after a 100 miles jaunt in rural IA.. Once they start humming - its the beginning of the end. Ask me how I know..
e.g. Ive done a couple roadside fuel pump replacements (in BMW's)..
1981 911SC
Old 06-03-2018, 02:32 PM
Functionista
manbridge 74's Avatar
Have you cleaned the pre-filter in the tank? It would be a drag to replace the pump and have the same noise from cavitation.....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-03-2018, 02:37 PM
It is loud enough to hear it even with bisimoto sound chamber so yes I can hear it.
No I haven’t cleaned he pre filter.
I’ve taken the pump out and all looked clean to me.
I have new fuel filter in the engine bay.
By the way where is the fuel tank filter located?
Old 06-03-2018, 03:41 PM
On the bottom, looks like a large allen head socket.
Chris
'75 911s Targa
Old 06-03-2018, 03:49 PM
Yeah I tried to remove that when I attempted to empty the tank, it was a no go it felt like I could brake the whole bolt out of the metal.
Not sure how much forse is required.
Old 06-03-2018, 04:18 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Just make sure where ever you buy it from, get a warranty, ask me why :-)
'85 Carrera Targa
PCA/POC
Old 06-03-2018, 04:20 PM
Here is a video of the fuel pump in action.
Is this considered noisy pump?
https://youtu.be/EsYqEnTwg-Q
Old 06-04-2018, 04:02 AM
High Life's Avatar
To check the pre-filter just take out the sender unit from the top and shine a flashlight done into the tank - you can see a layer a sediment (or not) from that viewpoint.
I wouldn't remove the bottom nut unless you are going to clean (or drain) the tank / filter.
1981 911SC
Old 06-04-2018, 07:31 AM
High Life's Avatar
No doubt..
I wouldn't mess with it - Its a cheap insurance policy to change. They can go at any time and Murphy's law dictates it'll be at the worst time.
Just google "humming fuel pump" if you're not a believer..
1981 911SC
Old 06-04-2018, 07:34 AM
will this fit my 76?
Old 06-04-2018, 09:24 AM
No, yours is in the rear and is different than the SCs
You can send the old pump out for rebuild.
I have put a turbo rear pump in there before.
Bruce
Old 06-04-2018, 10:07 AM
Mine is in the front
Old 06-04-2018, 02:03 PM
High Life's Avatar
My research shows: 91160811006 Assuming you have CIS?
Does it look like this one?
Fuel pump for Porsche 911 - Porsche Classic
Our host has a BOSCH unit for $110.. (Same Porsche part number - 91160811006)
1981 911SC
Old 06-04-2018, 02:11 PM
Still here
pmax's Avatar
Ticking is from the turn signal ?
Old 06-06-2018, 04:43 PM
Yes ticking is from the turn signal.
Old 06-06-2018, 05:07 PM
