window motor electrical connection - 1988 911
I am ready to pull out what little hair I have left. I need to replace the passenger side window motor in my 1988 911. Before pulling the whole regulator and motor assemble out I wanted to do one last test to make sure the wires from the switch to the motor aren’t the problem. I have not seen this type of connector before and have tried everything to release this connector. As my frustration builds, I’m afraid that I might break the connector. Attached is a picture of the motor showing the connection on the motor. I can wiggle the connector but can’t get it to release….please help.
1987 911 RSR Conversion - sold 1988 911 Targa 2008 Cayenne S 2016 Cayman GT4 |
Hi..don`t be afraid and pull .You are replacing the motor anyway so if you brake the plastic on the female connector you can easily use the same connectors with heat-shrink or new female connectors.
Also use some small screwdriver to pry the connector off... ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I don't have a pic of the female connector, but it has a center lock that I think you have to pull away slightly. I found this old mark-up that I did, hopefully you can see it and that you're trying to clear the tab on the male side.
HTH
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
yup i forgot about this beast..steely +1
Ivan
Hi Ivan - i was typing when you posted (bad habit ha ha). I was surprised I happened to have it saved, otherwise I would've forgotten as well.
Good luck to you dtimmester
steely & proporsche,
Thanks for your input. I'm trying to do this while it is still in the door so visibility isn't great. But your pic is helpful. I will try again tomorrow and hopefully have better luck. Like you said..."use the same connectors with heat-shrink or new female connectors."
Just FYI, in my case I spent about 2 years going nuts trying to resolve a random non working passenger power window. It ended up being due to a kink in the wiring where it goes from the body into the door. Fixed that and has worked perfectly since.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
