-   -   Engine tin difference between 2.7 and 3.0 (http://forums.pelicanparts.com/porsche-911-technical-forum/999768-engine-tin-difference-between-2-7-3-0-a.html)
jess p 06-16-2018 10:09 PM
Fellas
I tried to do a search but could not find any relevant threads. Are there any differences between the engine tin of a 2.7 and a 3.0
Thanks in advance
Flat6pac 06-17-2018 05:07 AM
The left tin on a 3.0 has an access hole for lambda probe 80/83
There is 1 hole and air channel on the left rear sheet metal for 2.7/3.0 which went with heat and air pump
80/83 was just the air channel tube.
Bruce
jess p 06-17-2018 12:11 PM
Thanks Bruce
