Engine tin difference between 2.7 and 3.0
Fellas
I tried to do a search but could not find any relevant threads. Are there any differences between the engine tin of a 2.7 and a 3.0 Thanks in advance |
The left tin on a 3.0 has an access hole for lambda probe 80/83
There is 1 hole and air channel on the left rear sheet metal for 2.7/3.0 which went with heat and air pump 80/83 was just the air channel tube. Bruce |
Thanks Bruce
