John Walker's Window Motor Fix
Does anyone have a link/bookmark to the thread where John explains how to fix the window motor?
I think it has to do with greasing the bearing that holds the shaft.
If anyone has it, kindly post it. Thanks.
Old 06-17-2018, 08:11 PM
LakeCleElum's Avatar
This one?
Window regulator help-Slow window
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 06-17-2018, 08:45 PM
The bushing at the end of the armature shaft gets stuck on the shaft. Two screws and pull the motor housing off and you'll see it. Work it off the shaft, lube and reassemble. May have to spread the bushing retainer at the bottom of the housing.
206 637 4071
Old 06-17-2018, 09:02 PM
Thank you John!
Old 06-18-2018, 12:06 AM
