912 Outlaw project
Hi guys,
We started restoration of a 912 The lead idea: Outlaw I will keep you posted. Here are some before photos ![]() ![]() ![]() ![]()
CarBone. We make cool stuff for aircooled enthusiasts. www.carbone.pl Engine DECALS in accordance with ORIGINAL. CUSTOM BUILDS based on aircooled 6 cylinders passion. |
Administrator
Solid looking Porsche - going to be following this build! Keep the photos coming!
-Dmitry |
Great, thanks!
That's so nice if I found it, if go stock original resto. Good luck with it though
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Engine out! (and more
![]() Thanks to @motopassiongarage we've just started on David's 912 '69 Outlaw project ![]() ![]() ![]() ![]()
There are no wrong ways to go with a car like that
Sure there i$.
If my '68 had been a numbers matching car in the shape of yours, I'd have gone Bone Stock original for sure. But as i said, good luck with your outlaw project.
Our 912 project for David goes well. Would you believe we found parking heating system in smugglers box? And it looks original!
AirBorne!
subscribed
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
Ouch.
If there is rust like that, check the front pan between the furthest forward front suspension points. It's hollow. You can access it with a digital probe through the battery tray. It rusts from the inside out. It can look perfect from the outside yet the metal can be rusted to almost a paper thin state. Most of the SWB/LWB cars I've worked on had this issue. I would run a probe inside the heater tubes in the rockers also.
Chris
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com Last edited by cmpski; 02-10-2017 at 08:51 AM.. |
Chris Thank you for the tip, I will make sure to check it out.
Kamil Quote:
Hi,
a quick update after a long break ![]() 912 is back from the first visit at the body shop, new body parts are in. Now it's waiting in line for a visit at the paint shop ![]() ![]() ![]() ![]() ![]() ![]()
Looks great. Painting it red again?
Motor plans? Trevor |
Paint, we are planning to use Silver Metallic.
Motor, 912 Big bore kit ![]()
