-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Front struct (http://forums.pelicanparts.com/porsche-912-technical-forum/1011538-front-struct.html)
HUNGVN361 10-28-2018 10:15 AM
Front struct
Hello all,
I'm confused over how this struct fit in the housing.
The housing is a boge type from a 68 912. So I got a KYB 361004.
The last picture shows the insert in the housing with the large nut hand tighten all the way.
The question is, is it ok to have a slight play up and down about 1/8" and side to side about 1/16"?
Any thoughts would be so much appreciated.
http://forums.pelicanparts.com/uploa...1540746903.jpg
http://forums.pelicanparts.com/uploa...1540746914.jpg
http://forums.pelicanparts.com/uploa...1540746925.jpg
Peter Graham 10-31-2018 03:28 AM
I cannot say for sure with KYB's, but other strut inserts (Koni, Bilstein) have a spacer that sits at the bottom of strut housing.
Peter
HUNGVN361 10-31-2018 05:07 PM
Thank you Peter,
I checked with KYB support and they told me there should NO PLAY in any directions.
So I think I bought the wrong struct even thought the seller stated that it fit 1968 912.
peter leinberge 10-31-2018 09:23 PM
I think a lot of times there is some oil poured into the strut housing too.
mochaSC 11-24-2018 06:14 PM
just finished putting new bilstein inserts into 66 struts. old inserts were kyb and they had no play up/down or side to side. in the bilsteins, there is a spacer that keeps up/down play nonexistent. there should be no side to side play. without spacer there's about 1/8" up/down play. with spacer the gland nut secures things just right. I would get inserts that fit better. can't be good to have stressed parts moving around like that.
Joehubble 12-29-2018 05:10 AM
Did you ever get those shocks to work properly? I am needing skocks as well and saw the KYB brand for sale too.
HUNGVN361 12-31-2018 12:48 PM
Unfortunately no.. I have to spend a little more money. The KYB is not available for 68 model. The one I think will work is the sach boge insert. Just look up on ebay or pelican parts.
