Control arm removing
Hello,
I'm not really sure how to removed the a arm from the crossbar.. Any thoughts would be much appreciated. Is from a 1968 912. Thank you http://forums.pelicanparts.com/uploa...1543118344.jpg http://forums.pelicanparts.com/uploa...1543118363.jpg http://forums.pelicanparts.com/uploa...1543118384.jpg |
I use a torch and burn it out.
Put the crossmember in a vise and heat with a torch while wiggling the A-arm. |
Thanks, I did used a torch and try to pry it out ... won't move.. I think i will keep trying heat and see.
| All times are GMT -8. The time now is 08:29 PM. |
