912E-Cylinder deck height question
Installing new cylinders and pistons in a 2.0 for a 912E. The kit is the 94 mm 8.1 flat top kit from AA. The gasket kit contained 4-0.25 cylinder shims and 4-0.75 head shims. The old school mechanic next door says that the head space with just one 0.25 shim is too close and I should use 2 of the 0.25 base shims. So I am going to mock up the 1 and 2 shims and do the squished solder proceedure that is mentioned in Waynes 101 Projects.
Has anyone here had any experience with any of this? Any advice?
Thanks in advance!
Old 01-16-2019, 05:34 AM
ken burge
A deck height of .052 is a good number
Old 01-17-2019, 05:47 PM
